Could I replace the battery?
My Fitbit Blaze battery only lasts 10-12 hours. Is it possible to change the battery? If so where can I find a replacement battery? I know it uses a 167 mAh Lithium Ion Battery. I'm not having any luck finding one. The battery has never worked right. Fitbit sent me a replacement pebble. I'd still like to attempt to fix this one.
Has anyone found any battery replacement valid for Blaze?
I replaced my Blaze battery with this one from Amazon:
Fitbit Blaze Smartwatch Battery (Li-Pol, 3.7V, 120mAh) Replacement for Fitbit Blaze Smartwatch Battery
It's been about 2 months now and I am very happy. A charge lasts for about 3 days now.
Here’s where to get the battery:
Fitbit Blaze Battery
Here’s how to install it:
Fitbit Blaze Battery Replacement
crwdns2886500:0Replace a 170 mAh battery compatible with the Fitbit Blaze smartwatch. 3.7 Volts (V).crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$19.99
You should disassembly it and then check for it's battery and then you can buy a new replacement .
@acnologia how do you disassemble it and where can one get a new battery?
There's a video on YouTube how to disassemble. The where to get the battery is the real question I've looked haven't had luck. The battery is a 167 mAh lithium ion battery. Good luck let me know if you find one.
@oldturkey03 It's easy ,just use YouTube ,i have seen guides that do it really fast.
Anybody know the dimensions of the battery? There are a lot of 3.7v rechargeable batteries on AliExpress
The battery for the Fitbit Blaze is 3.2mm X 18mm X 30mm. 3.7V, If it's more than about 31 or 32 mm long, the new battery won't fit, so be careful.
Tracy Kirkpatrick crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 10,312
