This affordable large-screen Android phone sports a 5.7-inch display and large 3,400 mAh battery.
Why is my battery overheating
phone wont charge and says the battery is at a dangerouse temp, anything i can do to fix it?
crwdns2944067:06crwdne2944067:0
derekrobinson2287 first off make sure that it is truly your battery that is overheating and not a bad sensor on your battery. Does your phone get hot? Does the battery feel hot? Yes you do want to change the battery, but the "overheating? alarm can possibly be triggered by a bad circuitry.
My son and my cousin has the same problem. I'm really disappointed but the phone was free when we changed over to a new phone company.
It says it's hot but doesn't feel hot. I'm thinking malware.
My phone doing the same thing
My ZTE Zmax pro is heating up and draining battery etc. Its also more than a year old. I'm probably going to be getting a new phone.
crwdns2933315:08crwdne2933315:0
Yes before it explodes. If you cant remove it send it in if you hlave warranty, or find out how to safely dispose of it in your area, and do so immediately. It will swell and explode
It's nothing but cheap China product the way to fix a over heated battery on a zte phone is not to by one like I did.
I don't think it's my battery that's overheating, but just the phone in general. When I put my finger on the fingerprint sensor to unlock my phone the sensor is unbelievable hot. What should I do?
That's the same for mine
Change the battery immediately .
How do you change the battery when the battery can't be removed?
It happened when I put charger in and always stuck at 80% and give a red battery light
I had the same problem. My phone would get so hot it was almost impossible to hold. Have your power button looked at. Even if it looks like it's all the way up if it's stuck down just a hair it'll make your phone over heat. My phone runs like a champ now and never gets hot anymore.
phone charges fine with original equipment. if you use a gas station charger it will stop chargiong due to wrong amperage
I downloaded a battery temp sensor on mine. It seems fine. Temp is at 77… then 80… then 86… then BAM 197 and the phone shuts down. Has a warm spot near finger print pad but no where near “hot “
Just restart the phone and it'll immediately stop! I got my phone from the MetroPCS store for free and only a few times has this happened I will say that my iPhone literally would shut off in the cold and when I try to talk to Sprint or apple about it I just got well you have an Apple device isn't that great! so it's not as bad as having a device that when you walk into a warm environment turned back on and a hundred percent but once you go under 40 degrees it's completely Powers off to dead battery! Just restart the phone complete fix promise you
derekrobinson2287 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 15,969
