A 4-cycle straight shaft string trimmer manufactured by Troy-Bilt. This model is identified by TB675 EC.
Why is troy bilt spray oil from air fliter
why is troy blit spray oil from air filter
There is a breather pipe into the air filter and because of this, you will always get some oil into the filter. What I have found to be the problem on the ones I worked on was too much oil in the engine. It is only supposed to be filled to the line on the sight glass.
Check the oil level.
phillip crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 514
