Apple's line of PowerBook laptops was intended for the professional and power users. The PowerBook line includes the PowerBook 100, Duo, 500, and 5300 Series; the PowerBook 1400, 2400, 3400; the PowerBook G3, G4 Titanium, and G4 Aluminum.
top row number keys won't work
Number keys on the top row, one thru nine, and their symbols,
exclamation point over to asterisk, won't work.
Toggling the number lock f6 key does turn the numeric pad
on and off, but not the shared numbers six-seven-eight.
But 4-5-6 and 1-2-3 do work with the numeric pad along with
the side symbols.
All other keys work, including the top function keys.
Thanks in advance, I'm guessing I turned something off
accidently.
Hi! I think you may have a bad keyboard with a crimped wire in its ribbon cable, or some other form of damage. I can't think of a software issue or a "lock" situation which would cause this. I would use the relevant iFixit guide to remove the keyboard, and see if you can flatten out any creases in the ribbon cable, and then make sure the cable plug is fully plugged in when you reassemble it. A row of keys not working is consistent with one of the wires in the cable being blocked or damaged, or with having liquid damage, so unless you get lucky with the procedure I described you probably need a new keyboard. But, alas, they are fairly inexpensive. You may want to reset the pram and pmu as well, if only to be able to say you did. Good luck!
No one really has an answer, because no one figured it out. I randomly have this issue with my razor keyboard when i hold the FN key and hit a Fkey of somesort. Now im guessing you havent tried also holding shift +number to see if the !@#$ symbols appear. if they do, then try just tapping your FN key and see if that fixes it. depends on your keyboard and problem i guess. This was my solution
Thank you I also have a razor keyboard same issue, the Fn +F6 method fixed it :)
In Windows, search for and open Control Panel.
In Control Panel, click Ease of Access.
Control panel with ease of access selected
In the Ease of Access Center, click Change how your keyboard works.
Select 'Change how your keyboard works' in the Ease of Access menu
Uncheck the option for Turn on Mouse Keys, and then click OK.
Turn on Mouse Keys unchecked
John crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 34
crwdns2936753:030crwdne2936753:0 154
crwdns2942667:0crwdne2942667:0 33,950
