The TDK Trek Max is a wireless portable speaker complete with Bluetooth capabilities. The integrated microphone allows for speakerphone capabilities to any device that is currently paired to the speaker via Bluetooth or that is plugged into it. The auxiliary and USB ports make the speaker compatible with almost any device.
Speakers go silent when turn up
My speakers go silent when I turn up the volume. Usually ok at low volume. Does it whether fully charged or not.
• How long will it run at low volume before going silent?
• How low must the volume be to prevent it from going silent?
• I wonder if there is a firmware upgrade available for this device.
The battery pack is defective overall. Inside the pack are six recharegabke AA batteries, one or more have gone bad. Replace an individually bad battery, or the whole package. Amazon sells both types of batteries.
If you remove the battery and run it off the AC adapter only, it will work fine. This problem simply means the battery pack is defective. Inside the package are six (6) AA size rechargeable batteries. One or more AA batteries no longer hold a good charge and must be replaced. Either troubleshoot each battery cell or replace the whole battery pack.
Interim Answer. {Awaiting reply from TDK support.}
TDK Life on Record Trek Max A34 Troubleshooting
SYMPTOM : max volume is available when plugged into wall, but only limited volume when running on battery.
This symptom of going silent quickly when playing on battery at high volume did NOT occur when the device was brand new! [Bob]
Sound mutes if it's turned higher than 3 lights. If it is connected to wall outlet it will play at max volume [rolis.kungs - 07/26/2017]
Plays fine plugged into wall vol all the way up but if I run it off battery it will only go to about 3 full solid orange dots and then it shuts off. It will run for a long time off battery, but I have to keep it low. 3 dots or less. [Chris - 07/22/2018]
I have tried the RESET procedure, and the fix was only temporary — the symptom of ‘going silent’ returned, same as before. [Bob]
<TDK Trek Max A34>
scottshirley crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 633
