How do I replace the glass only?
How do I replace the cracked glass ONLY on my LG G4 without replacing the LCD display
If you have some skills you can do that, here is a little help:
I really would not recommend this route. The extra equipment you have to buy, the time it takes to separate the broken glass from the lcd, the risk of damaging the LCD while separating it, and the time it takes to remove the old glue from the lcd is not worth it. After that you also have to worry about permanent bubbles of the new glue between the new glass and the lcd.
You can replace the screen on a LG Stylo 4; I replace mine all the time. HOWEVER, unfortunately you can not replace the GLASS ONLY. You must replace the front end (or face) of the phone. You DO NOT need to buy a KIT. You only need to purchase the Front-End of the phone for replacement. Whichever color you want.
How do i fix my cracked screen
Presumably similar to these LG G3/G2 glass only replacement video, as LG G4 lcd construction is very similar to G3 and G2.
How how much does it cost to replace a front end on LG phone and will it work or could it possibly have problems would it be better to buy a new phone which is expensive or spend whatever your prices for replacing the glass mine is very cracked up please respond thank you
Just sent you a message I'm asking you to send it to my email rather than post it on Facebook cvj 602@gmail.com thank you I want the answer sent to the question I just posted to you
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 12,094
