Device repair and troubleshooting for the 7" RCA tablet released in 2014, identified by model number RCT6773W22.
Green Border around Screen
My RCA tablet has a green dash border around the edge of my screen. I have tried turning it off and a reset but still the border and the device will not work. When touched the border will move to a box or rectangle around the area touched. Pls help.
crwdns2944067:04crwdne2944067:0
can you post pictures of what exactly is happening? this is a strange issue, never heard of it before. If you are getting a red border, resetting the settings in developer options will fix that.
My son has this issue . What soes it mean??? Help
post pictures of the issue
How do i get rid of that green border around my fire tablet i can't get in to anything
I had this problem too, you have to hold the icon that you need to use until the green box pops up, and then double tap, once you have it unlocked, do the same thing (hold down and double tap) to settings, and turn off talk back (you might need to search it once your in settings, like I did) and then your tablet should be fine after that.
I am having trouble now I am stuck in my camera
crwdns2947821:0crwdne2947821:0
How do i get this green box from my RCA tablet
I would check if you accidentally turned on show screen changes in a developer mode. if not it could be a small internal crack in the lcd. UPDATE: re reading it you have an assistive touch on. look in your settings and accessibility settings and make sure everything is turned off
Liam Boland crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 4,585
