The sixth-generation Volkswagen Jetta, known as the NCS (New Compact Sedan) during its development, was announced in the North American market in June 16, 2010.
2014 VW Jetta S Oil Change Bolt question
The bolt is on very tight, which way do I turn so so I don't strip the bolt?
@garrett28 if unsure check on here
@garrett28 you will always find bolts tighten by turning them clockwise and loosen by turning them counter clockwise . the only exception will be when the bolts are spun ( moving ) and require reverse threads to keep them from spinning off. Like kaniggit49 said "Righty tighty, lefty loosey."
James Garrett crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 964
