Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
How can I clean out my Lightning connector?
My iPhone 6 seems to have something stuck inside the Lighning connector. As a consequence, I can't get the charging cable in, so can't charge the phone. Is there a recommended way (or tool) for cleaning it out?
Thanks in advance
This is probably bad practice but I clean lightning dock charger port holes with tweezers or a equivalent tool and make sure to not touch or bend the charging port pins inside the port.
I'm embarrassed to say but I also had a loose-fitting charging cable and thought the metal connectors were loose. Turns out that it was filled with lint. A pair of needle nose bent forceps were used to tease out a giant bezoar of lint from the connector cavity and now it works like a charm!
Bamboo toothpick works quite well in this situation. It's not metal so it is less likely to short out or bend the pins.
Many thanks Tom, it worked! I actually used a plastic toothpick from a Victorinox Swiss Army Knife, but it worked great. Pulled out a piece of pencil-sharpening and a small piece of sellotape! No idea how they got in there! But the lightning connector now clicks into place again and the phone is charging as we speak.
Many thanks!
Phil
Phil Dixon crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 4,638
