Why wont my shift button work
After using my computer for a while, my shift button stored working. I cant figure out how to fix it.
One thing you can try is to carefully remove the shift key from the keyboard. You will see one or two clips and possibly a metal clip or something. I suggest taking a picture before you remove any clips. Then check to see if the rubber underneath is intact and cleared from debris. I recommend powering off the CB and use a Q-tip with rubbing alcohol to clean the area. It could be sticky or something is preventing the button from pressing down. For a Dell CB, I had to put a piece of folded paper because a student removed the rubber underneath the key. I would see if it exists and if that's not the case, see if the rubber can be moved. If so, carefully move it and see if you can press the button underneath and see if that works.
Have you spilled anything into it? If yes, then you probably need to replace the keyboard. Does it feel mushy or not press down? If it does this, then take the key off and clean under it. If none of these are the case reach out to ASUS to see if you have a warranty, if you don't, try replacing the keyboard!
i spilled milk on my keyboard and some of my keys dont work pls help
hi i spell milk on keyboard and now it break. im am so mad now cause shifts want work so i cant not do the question mark
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 2,573
