Nexus 6 Broken Coil Charging Ribbon Cable
I wanted to remove the back cover of my Nexus 6 to replace the battery. However, I accidently cut one ribbon cable of the coil charger.
- I know there are two ribbon cables for the coil charger. Does anyone know what each cable does? Is it for AC current or why does it need two of them?
- I do not use coil charging so is it better to remove the part or can I leave it in? I pretty much cut all through it, I do not know if this could lead to a short circuit by normally charging the battery via micro USB?
Here's an image of my Nexus 6's coil charging ribbon cable (if it's not allowed, then please remove): https://abload.de/img/img_39359bki0.jpg
