If I change the motherboard on my iPhone6s what will happen?
What will happen if I change the motherboard in my iphone6s?
@omar12708 the logic board is for all intent and purposes the phone. Replacing that board is like a different phone. Not sure what you are planning on, so give us a bit of a hint of what you are up to.
Well I lost all of my iCloud password and I have no access to my gmail so I can re get it back and the closets phone shop from here is 2 hours away. So if I restore it would basically be a new phone again I will have to put all my information back?
Note that restoring it will not remove any apple ID activation lock on the iPhone.
So iCloud would stay on it?
Yes, if it has been setup to have an activation lock on it.
You can check here: https://www.icloud.com/activationlock/
@omar12708 @benjamen50 is correct. IF the replacement logic board has a lock on it you cannot use it. So if you do buy a replacement you have to make sure that it is not locked. If it is not, then you must transfer all your information to your "new" phone. All your data on the "old" phone will be lost since it is stored on the logic board.
I have an iphone 7 with icloud locked.
Now seller is not giving me full details. I know that I purchased an expensive paper weight.
Now I want to make my phone in running condition. Is that possible if I change its mother board/logic board to use it normally.
Will that phone start as new device?
Can anyone help me then i will go for board purchase.
Thanks in advance.
Yes, it will. This will fix all your issues, just make sure to buy an icloud UNLOCKED one with the original home button included.
Can we use the home button from the current phone and only change the motherboard, will the button work?
does the same work iphone 6s?
My phone is dead now.. I don't know what happened it has shut down.. So if I change its motherboard can I use it like a new one??
i have iphone 6 and ther is icloud on it if i change the lorgic board can i get it unlock
You have to make sure you change the logic board (motherboard) with an iCloud UNLOCKED logic board that includes the original home button for that particular logic board, or your touch ID won't function correctly. Also, this may sound like a dumb question, but have you changed the battery yet?
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 31,121
crwdns2944067:09crwdne2944067:0
Ok I have a similar problem but mines a new phone model I forgot my new email and by it being a new phone I didn’t get chance to remember the number so I cannot unlock it so if I change the motherboard will it fix the problem
crwdns2934271:0crwdnd2934271:0 Kiya & Keira crwdne2934271:0
definitely it can fix the problem.
crwdns2934271:0crwdnd2934271:0 Y.music crwdne2934271:0
even the phone is in lost mode.. :-(
Also I want to upgrade it to 128gb but old phone is 32gb. Pls advise what should I do?
crwdns2934271:0crwdnd2934271:0 moon_f123 crwdne2934271:0
If I got an iCloud locked iPhone and I change the motherboard what will happen
crwdns2934271:0crwdnd2934271:0 W Spring crwdne2934271:0
If i change the motherboard of my iphone won't apple block it when i try to access my icloud account?
crwdns2934271:0crwdnd2934271:0 Bulelani crwdne2934271:0
crwdns2934275:04crwdne2934275:0
