Camera failed to launch
I am getting this error on my zenfone 2, is there anyway to know if this is due to a hardware problem or a software problem? Any place where i can buy the camera replacement?
My country doesn't have Asus service
Actualización (25/07/16)
I have disarmed and note that the front camera was incorrectly connected , connect it again but the error persists, something I can try?
crwdns2933315:09crwdne2933315:0
you can use the calculator test benchmark for see if is a hardware problem.
open the asus calculator and insert .12345+=
It says Something wrong with Main Camera Capture Test!
is it hardware right¿
crwdns2957956:0crwdnd2957956:0crwdne2957956:0 crwdns2950251:0crwdne2950251:0
looks like, I have same problem.
also front camera is not working or only back camera ?
Sir , I did so (.12345+=) . Flash is working & showing test passed but cemara showing black ..
Kindly advise me to solve the back cemara problem
Prasad , Hyderabad
everytime i test the camera features the SMMI TEST shuts down. I have problem with the camera not working since last week. Everytime I try to open the camera, it shuts down by itself and tells me to restart the cellphone and when I do it the problem persists. Can anyone help me with this problem? Thank you.
Try doing a battery pull..
  1. Turn off the phone.
  2. Remove the battery.
  3. Wait about 5 to 10 minutes.
  4. Put back the battery.
  5. Turn the phone on.
Hope this helps.
I got the same priblem now and im browsing the answer how can i fix it.
my phone was dropped and i found out 1 of the small component was missing, soldered the missing component as a joint (make it short jumper) after that camera starts working.
just look carefully at all the components should be something loose or missing …
Hi. I have the same problem and same situation (my country does not have an Asus support centre). All I can tell you for now is that buying a new camera will not solve the issue. i found one at a good price on AliExpress and had it shipped. Waited for the longest time for it to get here, only to find out that the issue is not with the camera itself, but with the logic card. And having no support centre nearby, fixing the logic card will not be happening anytime soon.
Sorry to be the bearer of bad news.
Asus have fixed the problem by ota update on October 26th
You just fallow the link to update your camera into a next level
https://youtu.be/UOYooxdVwBQ
Follow the
https://g.co/payinvite/a9cy00
Follow the link for info of Asus camera problem
You can mail me on ghosh.sumanfot001@gmail.com
All camera problem will solve
See that tutorial video
This is what worked for me. I have no idea what steps are essential.
The camera on my zenfone was dead. Every diagnostic said it was dead.
I did a factory reboot. The camera was still dead.
A couple weeks later, I rebooted the phone. I laid the phone flat on a surface so that the lens would only see dark.
I fired up the camera app. Let it sit for a minute. Went from the rear-facing to the front-facing setting a couple times. I picked the camera up, and for a few days it has been working fine.
Kinzo Edge crwdns2934231:0crwdne2934231:0
crwdns2959996:0crwdne2959996:0 19,919
