The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
pink dot on screen after fell into water bowl
my friend's phone fell in a water bowl for 3 seconds and it has a little small pink dot , i want to know is it fixable or should she order another phone? thanks for helping me !
@kaye what have you done to fix the water damage? the more you mess with the phone, like turning it on etc. the more likely you are to shorten out the logic board. At least remove the battery for now. STOP USING IT
In answer to your question, yes, it is fixable. But as @oldturkey03 pointed out your friend should stop using the device until it is properly fixed.
Water damage is fickle in that it can seem fine initially, but then give you some unexpected curveballs in the near future. For the best possible outcome and the longevity of the device you should clean it properly in an ispopropyl alcohol solution and clean any signs of corrosion, along with replacing the battery. The pink dot, depending on the location (like on the LCD), may not go away until/unless the screen is replaced. With these devices, that can get quite expensive.
To summarise:
  1. Stop using the device.
  2. Replace the battery
  3. Clean the logic board
  4. Replace the LCD
If you feel like this is out of your capabilities just take it to a local shop and ask them to do a repair on it!
Kaye crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 126
