A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
Why is my washer spraying oil out the bottom?
Oil is spraying all over the floor under my washer. It also is extra noisy.
older model bravos. Mine has brushless motor drive.
@mikehaase
What is the model number of the washer?
tills00 most like your washer is leaking from the main bearing and seal for the outer tub. is starting to fail. Part number for that is W10435302 and this video will help you replacing it.
Just to add to Mikes answer it would be a good Idea to stop using the machine until you have replaced the seal in the transmission. A seal is a lot cheaper to replace than the transmission and continued use will cause damage to the trans
tills00 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 13,741
