Repair guides and support for C/K pickup trucks sold by General Motors under the GMC brand, including the GMC Sierra.
Locate vacuum hose by transmission
Locate vacuum line to transmission
crwdns2889612:0crwdne2889612:0 9
crwdns2944067:015crwdne2944067:0
Hello everyone I have a gmc 1500 4x4. I replace my trany and as doing so I don't know were the black rubber hoes connect to I do know that one go's to the transfer case and the other one gos to the tranmission but don't know were the other ends go to
And they both have plugsat the end of them I do remember are i think above the transmission there was a bracket they was connect to some please help me 28th pic
Same problem, tranny won't shift into third . 1989 Chevy Silverado. 4x4 5.7 motor . i need some kind advice on what i should do as far as do it myself or take it to shop.
@marciano68 You can start by checking the fluid levels in the trans when the truck is warmed up to normal operating temps.the trans fluid level is checked with the engine running in park . If its low it may be a good time to change the fluid and filter. If this brings no joy then you may need to seek professional help
Can u show me a picture of we're it goes
http://67-72chevytrucks.com/vboard/attac...
In this picture the line is steal but runs from the throttle body down to the tail of the trans. Its the silver line next to the trans dipstick tube
crwdns2934275:010crwdne2934275:0
The year range is pretty non specific.
If the truck has a vacuum hose to the transmission (to the vacuum modulator), the line will be a metal tube attached to the large tube that the transmission dipstick is in. It will come up and connect to a hose that will run to the base of the carburetor.
The function of this line and the modulator it goes to, is to give the transmission some sense of how much throttle is being applied during a shift to make the shifts softer or harder depending on load. The transmission will work without this line, but the shifts will be hard as if the throttle was all the way to the floor.
If the hose is broken or missing, there will also be a vacuum leak at the carburetor, causing a rough/high idle and possible an intermittent backfire.
If the truck is new enough, the transmission will be electronic and not have a vacuum modulator at all, and will have a plug with several wires connected to it on the drivers side.
crwdns2889612:0crwdne2889612:0 15
crwdns2944067:016crwdne2944067:0:
i was wondering if the transmission has an overflow tube(rubber)cuz if not then i need to know where it goes. reverse is not working, but it will back up in 4 wheel drive low only when its cold. i put tranny fluid in yesterday nothing showing on the dip stick and it started leaking out that rubber tubing. the tubing in on top of the tranny itself. it s 700r4 in 1991 chevy truck 4x4. can u please help me?
where is the vaccum hose?
On a manual 3speed
I have a 1989 K 1500 and I have shifting problems to the truck was fine everything was fine with the truck it ships great and hoard it just won't ship until I get to a high RPM it's an automatic I've checked the vacuum of check the modulator I'm not sure if it could be the torque converter or what but it will not shift into 2nd until it gets to a certain speed and it won't shift into 3rd until a certain speed and by that time the motor is wound out
I'm having same issues with 93 c1500 I'm beginning to think its a defect with the transmission.
crwdns2934275:011crwdne2934275:0
My old transmission that was in my 94 gmt-400 didn’t have the vacuum hose but my th350 does
bagwelltanya16 crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 69
crwdns2936753:030crwdne2936753:0 272
crwdns2942667:0crwdne2942667:0 111,823
