The Apple Magic Mouse is a multi-touch mouse manufactured and sold by Apple Inc. It was announced and sold for the first time on October 20, 2009.
How to change rechargable batteries
I have used a magic mouse with the rechargeable battery pad for several years. The mouse works fine but the battery life has been dropping significantly. I have let it completely drain then completely charge and saw no improvement.
I saw somewhere that the battery compartment can be opened and inside are two standard size rechargeable batteries that can easily be replaced.
Is this true? Does anybody have experience with this? Where can I find a small hex shaped screw driver to open the compartment?
The videos online show that there is no tools needed. Maybe you need to google your model.
I'm guessing you have the most recent model that is charged via lightning cable? I'm guessing there might be a little confusion from other fixers, as most of us are used to the older model of the Magic Mouse that had the standard user-serviceable battery compartment. From the sound of your problem, it sounds like the rechargeable battery built in has reached the end of its effective lifespan. If it is the newer version, I recommend updating your question to specify that your device is the Magic Mouse 2 to avoid confusion.
You can find the teardown guide for the Magic Mouse 2 here.
It appears that the battery pack in this model can be replaced - however, adhesive is used in addition to screws to hold the mouse together, requiring a tool like the iOpener or something similar to take it apart. If you are feeling adventurous, you can give it shot - the battery can most likely be purchased directly from Apple (if I asked about MBP sata cable from them before, and it was possible to purchase the part by itself.) - although considering the use of adhesive in the Mouse's design, its worth considering paying for one of the Apple certified techs handle the replacement install for you.
z3634802 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 490
