Lost my blue tooth after a battery change
I changed my battery and did not check the blue tooth, now I can't connect with blue tooth. Is one of the internal cables that are disconnected during a battery change part of the blue tooth circuit?
The bluetooth module appears to be on the logic board so no internal cables that are unplugged (if they are needed to) are connected to the bluetooth.
I'm quite puzzled as to what would cause this, maybe the back cover housing isn't put back on properly or has gaps?
