Repair guides and support for top and front loading Whirlpool brand washers.
crwdns2934591:0425crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Need to get to the front panel whirlpool washing machine wwdc 8420
Hi all
The button on the front panel of my whirpool wwdc 8420 has come off so I cant press start/stop
Can anyone tell me how to get to the front panel from inside please?
Many thanks
Perhaps you might start by removing the top panel; usually it will pop off the top and is clipped in. Under that, it should become more evident how to proceed further. perhaps take a picture for us once you get there?
crwdns2942205:01crwdne2942205:0:
start up swicth is blinking after set to operation
Ensure machine is isolated. Take the top-off, which is held in by 2 philips screws at the back. Then depending on the model there may be a bracket support plate at the front which needs to be removed, either way the front display/control panel is held in place by 2 screws on the top of the machine and either 2 or 3 screws through the front of the soap dispoenser housing. The timer/display module is generally held in place with plastic clip-mouldings. The buttons are located behind the circuit board…generally.
AlexKnight crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,085
