Repair guides and support for full size headphones that encompass the entire ear, also known as circumaural headphones.
JBL Synchros E50BT Broken Charging and Audio Port
JBL is wireless but also can be used using a wire, and I dropped it, with the wire on and broke the charging and audio port now I cant charge it anymore. can you help me fix it? :(
Update (07/02/2016)
my broken charging port looks like this
and the normal thing should look like this :/
Have u fixed it? And how?
I have disassembled the left ear speaker and have pictures and can take measurements of the 2.5mm jack. There is a 4 pin plug which has leads from the jack PCB board, blue, red, green, white. The PCB holds the jack socket and is mounted to the ear housing with 2 small screws. The jack socket is SMD mounted with 5 pin pads - 2 at the top flanking near the insertion, 1 left middle, 1 bottom right, 1 bottom center. https://i.imgur.com/tVm45Bv.jpg
I am going to call JBL to find out if I can obtain the replacement PCB.
crwdns2933315:09crwdne2933315:0
The part you need is: SA-HM14PA0300-B
That'll get you the small PCB with the charging jack (new part).
Costs ~ $9 + shipping
Call JBL Tech Support @: (800) 336-4525 (also on JBL support website - link below)
Last I checked they still had a couple in stock.
Note: You'll need to de-solder/re-solder the wires back to the replacement part, so find help if you don't have soldering experience.
https://www.jbl.com/support-product.html
We need the picture of other side
If you can open it up and find what perhaps the pad pattern and jack should look like, possibly you can find the same piece on AliExpress and then buy it and resolder it on. it involves surface mount soldering though, most likely.
my jbl e50bt broken
length adjusting part is broken
what i do now?
Hey, first of all you will need to open it. I recommend you to go to this video link to learn how:
https://www.youtube.com/watch?v=1CMVoqfh...
Very helpful for the issue. And be careful with the pins... so tricky!
Charging cable problem
https://www.ebay.ie/itm/362477615693?ssP...
does this work?
hi
i need to replace the head band due to a repair agent ripping it is this possible
Cheers
I have JBL headset but I cannot locate the charging port so I need help
The charging port is the same port used by the 2.5mm jack on the left ear side. It uses a USB Type A to 2.5mm male jack supplied cable. If you are missing that cable, you should be able to get a replacement from JBL.
I have JBL headset but I cannot locate the charging port I need help
jkradi crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 7,498
