The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
Replacing turn signal/wiper/cruise control combination switch
I have the replacement parts, but need some information in replacing the old one.
Simply pull off the rubber cover, using a flat screw driver to help if needed. You will then see a bolt that holds the assembly in place, and a few screws that hold on wires. Remove those, and then unplug the wire harness plug. With all that done you should be able to pull out the old switch. Installing the new switch is just the reverse of this.
Mike Wood crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 801
