Why motorcycle 50-60 speed after started shake
how to maintain my Bajaj Discover DTS-i 100cc bike
@harikall if the wobble is felt in the handle bars and goes away if you use both hands pushing somewhat against the bar, then it could be the stem bearings. Otherwise there are a few more possibilities. Could be caused by a bad tire, bad wheel bearing, and an out of balance wheel. Easiest would be to start by getting the wheel professionally balanced. As for maintaining your bike, here is the maintenance chart PMChartDiscover100.pdf
to check the stem bearing simply raise the front wheel off the ground and see how much movement there is in the bearing
The master of manuals strikes again. It never ceases to amaze me as to the manuals you can find
@jimfixer I'll leave you my collection when I retire ;-)
A motorcycle shaking at 50-60 km/h is often caused by issues with balance, alignment, or parts.
According to my motorcycle repairing experience in the past 8 years, the following are the most commonly seen reasons:
Regular maintenance and inspection of these parts can help identify and resolve the issue, ensuring a smoother and safer ride.
I've heard of front tire ply separation causing this problem. Try setting the bike up so that the front wheel can be spun and watch for a wobble in the tread. I would also look for a wobbling rim caused by a loose spoke or bent rim. A dial indicator would help with this check.
By the way , whats a 5 stroke?
Lean petrol
Bad engine mount
Air filter blocked
Engin riper smoking
Engin repear at bike shmoking
crwdns2936753:07crwdne2936753:0 72
crwdns2936753:030crwdne2936753:0 287
crwdns2942667:0crwdne2942667:0 4,974
how i can repair the batterie of the bajaj discover
crwdns2934271:0crwdnd2934271:0 KEEP Editing crwdne2934271:0
