Part behind the front camera
Hi,
I had to replace the back cover of my iPad 4. For that I had to remove all parts from the old back cover. No problem so far, only the flat cable of that part behind the front camera was damaged. Does anyone know which part that is? And further where I can get a spare part?
Before I started, the iPad worked fine but now the display seems to be not working anymore. When I connect the iPad to iTunes the iPad communicates with iTunes without issues. So it seems that the iPad works fine except the display.
Any help would be much appreciated! Thank you in advance :)
@mihe post some pictures of what part you are referring to, with your question. Use Adding images to an existing question this guide for that.
Just found out which part it is. There are 2 parts behind the front camera. The GPS antenna and the microphone. The one I was looking for is the microphone.
Just found out which part it is. The one I was looking for is the microphone.
