Headlight replacement for bmw 328i
How to replace headllight
Changing the headlight bulb can be done without any tools.
You will have to turn inwards and outwards in order to remove the access panel located in your wheel housing. Using a coin can help opening the shutter of the access panel. After rotating boh retaining clips, remove the panel.
Remove the back plug before removing he retaining clip of the bulb. Remove bulb by rotating it carefully.
Install new matching bulb the way you removed the bulb inbefore. Close back plug. Put the access panel back on.
I found this Video to be useful when changing the headlight bulb of your 328i
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 5,860
