Doris, did you remember to remove whatever you used to keep the motor from turning when you replaced the blade? Check the oil level and make sure there's some on the dipstick. If everything looks good up to now, try removing the spark plug - so the motor turns easily - and turning the blade by hand, in the proper direction. (If I remember correctly, that'll be counterclockwise looking at the blade from underneath the Toro.) Of the motor turns, there's likely a problem with the pull-starter. You'll have to remove it from the machine to find out what's wrong. If the motor does _not_ turn with the spark plug removed, the motor is probably seized up - a major headache! IF this proves to be the case, remember in the future to _always_ check the engine oil before every use.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
0
Doris does thee ripcord come all the way out and will it go all the way back in ?or is it only partly returning
crwdns2934271:0crwdnd2934271:0 Jimfixer crwdne2934271:0
