Black line down the middle of the screen
My Samsung 48 inch TV screen has a black line going down the middle of it.How can I fix it
jamesfry817 sounds like a TAB error on your LCD. Put some pressure on the tabs on top of the LCD where the line is and see if pressure on that changes it. It might help if you post an image of what you see with your question. That way we could see what you are dealing with. Use this guide for that. The TABS are at the end of where the little ribbon cables, that go from the LCD controller board, into the LCD panel.
How do u fix tab error
@lightbeauty a TAB error is very difficult to fix for a DIY'er. This is where the ribbon cables enter the actually LCD. Those cables are bonded (to the panel. If that bond fails your cable no longer makes contact with the LCD panel. Sometimes some electrical tape or even duct tape may exert enough pressure to close that connection. If that does not work then there is not a lot one can do to fix it. This will of course depend on where it failed, how much has failed etc.
I have the same issue with a black line in the center of my screen
james schoener most likely the same issue.
This seems ro be happening to all curve samsung big screen tvs. Including mine and it is new out of the box. Why isnt this a manufactors recall?
crwdns2934073:0crwdne2934073:0
This is my screen
My tv is not curved but a black line appeared yesterday, I have reset the tv, still there
My tv is not curved either and I have the same issue
Did u find a solution? Mines doing the same
crwdns2936751:024crwdne2936751:0 25
crwdns2936753:07crwdne2936753:0 170
crwdns2936753:030crwdne2936753:0 703
crwdns2942667:0crwdne2942667:0 174,969
crwdns2944067:023crwdne2944067:0
I have a samsung 50" model #PN50C430 and i have one line vert and one hor i just wonder if you new what was causing this
crwdns2934271:0crwdnd2934271:0 wadegoulding crwdne2934271:0
wadegoulding those are commonly caused by TAB errors. If you take some picture and post those with a separate question we can probably ashow you a bit more
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
Hi I have a 55" Samsung smart 3d tv. There is a thin black time just down from the centre of screen. It runs from left to right. What is causing this
crwdns2934271:0crwdnd2934271:0 Carlena crwdne2934271:0
So I have a 55 in hdr tcl. And I left my PS4 under the tv and I guess the magnets in it left a black lil hole at the bottom of my tv and now there’s a black line showed on it. Is my tv destroyed or is there a solution
crwdns2934271:0crwdnd2934271:0 paul720m crwdne2934271:0
i have a 55 inch curved tv. i have a black line going down the middle that colored lines in the black,what is this caused from.
crwdns2934271:0crwdnd2934271:0 lisabest0630 crwdne2934271:0
crwdns2934275:018crwdne2934275:0
