Remove screw ?
I'm on step 3 of the instructions for installing a new hard drive in my Powerbook G4 15" 1.5-1.67 GHz. One of the 2 12 mm Phillips screws in the memory compartment won't budge. Any suggestions ? Thanks !
crwdns2889612:0crwdne2889612:0 -1
Stuck screws are very frustrating!
Don't just torque on it blindly, as stripping the screw will leave you in a very poor state.
Try briefly using a hair dryer on the area to loosen things up (don't point the heat at the logic board for long, though!).
Then, with the CORRECT screwdriver size (#00), push firmly down directly into the screw and, while pushing down, turn the screwdriver.
The downward force ensures maximum drive to screw connection, and minimizes stripping.
I hope this helps!
use a magnetic screwdriver. Make sure you have the right size too.
Or get someone strong to have a go!
C Cremers crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 1,435
