The drone is a Wi-Fi capable and it's equipped with a built-in HD camera. It is used for taking pictures and filming. Model number: PF722000
The light on the drone blinks green then turns red
After I had an accident in which my Parrot Bebop fell about 75 feet, I could not turn the drone on again. When I pressed the rear light to start the drone, first the light blinked green and then turned red.
I at first thought the problem was one motor that had been damaged. I replaced the motor in question, but the light still blinked green and turned red.
Eventually, I took the drone removing the motors, camera, and gps until there was only the motherboard connected to the battery. Now, I still get the same response. When I press the turn on button the light blinks green and then turns red.
Do you have any suggestions for repairing this Parrot Bebop?
Have you found a solution? I have the same problem and am unable to find a cure anywhere.
This has to do with either
Disconnected motor
Or disconnected GPS board
i am working on mine right now and it seems that the motor drivers have an open ground or negative, when powering on the motors should activate a few short pulses. my drone does not, but you know guys it would be a !&&* of a lot easier if they would supply a circuit diagram
Okay, so I took the drone completely apart and searched for any connections that might be questionable. I did not find any obvious issues, just for being able to say that I did something I reflowed the power connections to the mainboard and reassembled the drone. It is working again. Very nice construction of the mainboard. I would say, it's probably 5 layers thick.
cmitc crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 3,144
