Released in October of 2014. This model, SM-G530H/DV Samsung Galaxy Grand Prime, comes in a White, Gray, or Gold casing.
How can I remove FRP lock from my Samsung mobaile?
I was hard reset my Samsung mobile ( GRAND PRIME (SM-G531H) ). Now I can't set up my device without entering the e-mail previously synced with this device. I didn't remember my old e-mail. so how can i unlock my device from FRP lock..?
crwdns2889612:0crwdne2889612:0 51
crwdns2944067:024crwdne2944067:0
Fortunately there are many ways to get rid of this issue. There is a complete method to UNLOCK FRP from Samsung Galaxy Grand Prime. You should give it a try, I'm sure this will help you.
That's not true. If the phone is already locked it is more difficult because the GP does not support OTG.
Wats the easiest way to remove a from lock on a S5 I bought and can't use plz help
along with many others i can get into a phone now because google has me lock out ...what control are they goin to want next its my phone i should be able to use it please help
i can remove this for you contact me on skpe "spotthemall"
crwdns2934275:019crwdne2934275:0
crwdns2933315:011crwdne2933315:0
There are few methods available which can help you to Remove frp
Steps to remove frp using OTG cable:-
you can use OTG cable and place APK file in pendrive
then connect the OTG to phone
USB storage will appear
Install the APK file
and open it you will be in Setting
then click on Backup & Reset ->Factory data reset->Reset device-> delete All
or if this method fails or you does not own OTG cable, try another method
Samsung FRP unlock without OTG cable
this metod power on all phones , read
https://frpbypass-gsm.blogspot.com
Samsung FRP Unlock All Models All Security Patch guide here.
https://unlockerplus.com/all-samsung-frp...
Yes this service can unlock any Samsung FRP lock device even Samsung Note 20 FRP Unlock as well.
look at this tutorial
remove frp lock samsung 2016 100% tested
https://www.youtube.com/watch?v=YPFAJQZ1...
Don't work all the time
It is siple to remove if ur device locked!
Open device in lockscreen than make an picture after go in cameramode to galeri and try to send the picture example via email. Perhaps u cant send and devive will redirect you to securety options than disable cloude and wola ur device is open ;)
disable what?
You must download a aol app to remove it and will cost 20 dollars
I was playing
This one will probably work https://drive.google.com/file/d/0B3goqmz...
not working link
https://youtu.be/oyyGseKMbq8
frp lock remove please help me my phone g361f samsung
I have been looking for the same issue to remove FRP Lock from my Samsung Galaxy S7 Edge and I had found '''Samsung FRP Unlock Tool''', which has helped me to remove FRP Lock very easily. You need to be a bit technical.
Check here to know the all Latest Samsung Devices FRP Bypass problems-https://www.gadgetsdr.com/category/samsu...
Click here to find a complete solution to your problem ++https://minitipsx.com/samsung-account-lo...
dilshankavindu crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 121
crwdns2942667:0crwdne2942667:0 86,258
