problem with xerographic system
How we rectify problem with xerographic system
- Xerox 5755 geographic failt and paper jam left door
Sent from my Che1-L04 using Tapatalk
- Hello,try chg the cleaning motor for main charge.this motor located at rear main motor
- Try another drum. Clean transfer unit. Remove ALL trays and BE SURE NO paper or debris behind trays and up in top areas. log into diags mode and clear codes then let it fail then go back in and look at code. Trace code and you will find problem and fix.
- Reporting your fault codes would be a help in troubleshooting. For example, if the xerographic faults are occurring with 9-060 faults, you could have a faulty High Voltage Power Supply or poor connection on the board.
- Originally Posted by Exok
sir i have this issue then i changed 4b unit (blue handle unit) and also i have installed stabilizer but stll now i have these issue with error code 9-560 what to do please help me
- Xerox 5755 foult code :- 03-480 power supply foult
03-777 sip recovered form an uncontrolled power loss
how to solve this problem dear frds.......
May i change new power supply unit but the action is continued...........same foult
and service full machine.......at one by one all part.....
And i replace the power supply change with other machine that are work perfect and complete
Drum Chips problem,removed or replaced
xerox workcentre 7835 "altboot" full driver
crwdns2942667:0crwdne2942667:0 6,457
crwdns2944067:04crwdne2944067:0
how we rectify problem with xerographic system
crwdns2934271:0crwdnd2934271:0 Dharmendra Pandey crwdne2934271:0
Plz help me xerographic fault
crwdns2934271:0crwdnd2934271:0 ali crwdne2934271:0
Please help me xerographic fault Xerox 5755
crwdns2934271:0crwdnd2934271:0 Bharti Xerox crwdne2934271:0
