The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
2014 and 2015 battery interchangable?
Hey guys,
Recently bought an early 2015 MacBook Pro 13" which had light water damage.
Opened it up and gave it a quick clean (rice everywhere...)
Only problem I can see is the MacBook can see the battery but wont charge and says it needs replacing (only 17 cycles)
The MacBook only works when connected to the charger.
Now I have a 2014 MacBook Pro 13" which functions normally.
Can I plug that battery into the 2015 model to test that it definitely is a problem with the battery before buying a replacement?
Don't want to waste money buying a replacement battery if that wont fix the issue.
Cheers!
*Update*
Info from coconutBattery
The batteries are different and at 17 cycles is most likely not the issue. It's also a very difficult replacement. Here's some info on it: http://www.everymac.com/systems/apple/ma...
First see if you can get a better idea of its status by downloading and running Coconut Battery:
http://www.coconut-flavour.com/coconutba...
Just updated with info from coconutBattery.
Is there anything else I can do to try and diagnose the issue?
Looks like the next step is to replace the I/O board. What does the mag-safe do when you plug it in and have you tried swapping chargers?
When the magsafe is plugged in its green for a second then turns amber.
I tried with my 85W magsafe and it does the same thing.
Is there any way I can diagnose with a multimeter?
That is normal behavior for a battery trying to charge, Leave it plugged in for a few hours with it running to see if it charges the battery up and it will turn green when fully charged,
It's been on charge for 2 days now and the current charge has gone down to 361mAh.
I also noticed the fan isn't running at all? Is that normal?
It doesn't seem to be over heating but I just thought the fans were constantly on?
Cheers!
Harley Borg crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 289
