Considered one of Sony's best smartphones, the Xperia Z Ultra is a 'phablet' style device released in 2013.
Phone starts charging but stops and starts a few seconds later
I plug my Xperia Z ultra into the wall socket for charging and it starts to charge but after a few minutes it starts beeping "the plug in to charge sound" and doesn't charge. The battery is good I think, because the small amount it does charge holds a very long time. Can anyone tell me what might be the problem - I thought it may be a charger connection problem but when I wiggle the cable it makes absolutely no difference. I love the phone always been a good one but this.
So I switched the phone off, plugged it into the charger and it started draining the battery, yeah, the charge went backwards, I got it to 46% and it drained (over an hour) down to 18% before I realized what was happening.
crwdns2933315:09crwdne2933315:0
It sounds like the power nub (the thing that plugs into the wall) is going bad, android phones refuse to charge from "dirty power" sources so get a new power nub one that's not from some bin in Walmart or something and it will be better if you get one that is 2.1A
thank you so much! i had the same problem but replacing the power nub fixed it! :D
i got the exact same problem for the past months....on my doogee y6 max. The phone needed magic to charge . I had to place it in such a way that the phones weight would apply force to the usb connection and in a certain angle upside down sometimes it would charge. Finally it lost that as well and went dead like a brick.
Send it to a repair store and got it back today actually....
The technician said the following...."i changed the usb .....charged it but it doesn't hold the charge and every few hours to 4 hours max it discharges....Its not the battery since we tested it and the battery seems fine, its not the usb since we changed it, so it must have something to do with the plaquette of the mainboard."
"somehow in a specific part of the mainboard there is an issue that drains the battery and doesn't allow it to fully charge"
Thats what the technicial said.....
Now either the tech shop are a bunch of noobs or my mainboard has an issue as they say.....
The phone came back and i plug it in a barnd new 4 hub usb plug with new usb cables and still charges for 4~6sec then stops.....STILL LOOKING FOR A WAY TO FIX THIS
I just plugged my phone to my ps4 instead of my adaptive Samsung charging block and now it's still charging it use to show charging for 1 second and stop but it looks like it was my wall plug part of the charger
did u ever find the solution? im having the same issue
Exactly Same thing is happening with my moto g5 plus, firstly it made chnge 4-5 usb cables within 2 month, then it works absolutely fine for 2-3 months when i get rid of my default turbo charger and switched to standard charger 15A 2v, then again it only gets to charge when switched off, still facing isuues, service centre raised their hand on this issue after many attempts….
that is exactly what my moto 5g is doing right now
Same problem… my Samsung Galaxy A70 charge for a few seconds the it stops, the original cable seemed to stop working so i bought a new one it worked a few days now its like mentioned before… when i stick it to my laptop it shows the sign for charging but the battery percentage doesn´t rise or even fall sometimes even when i am in low energy mode… I´m on vacation in thailand for 6 more weeks i don´t want to buy a phone here or bring mine to a repair shop i really don´t know what to do
I have a brand new iPhone 6 and I have the same issue- it’s infuriating to say the least .
This looks like a software issue. Check out doing a factory reset after backing your stuff up to micro SD etc ES fileExplorer:appBackup etc then reset. Battery stats bin can be hacked or altered between OS and updates or FOTA firmware Over The Air updates that can seriously inhibit functionality (think @pell a few years ago). So try that. Or if you have root, try battery stats erase via root app.
https://forum.xda-developers.com/showthr...
-nand26
I got an A50. Had an issue with the charging. Phone charged good until it stopped showing the Fast Charge notification. It shows only charging now for a few months. Now the phone wont charge with any charger. Im thinking of sending it for repairs. Tried all the restarts even in safe mode. Still wont charge. Tried charging while phone is off still wont work. Tried original charger of someone else but stil wont work. Duno what this is and the phone is barely more than 18 months… Will send it in and hewar what they have to say… But never haf an issue with normal usb. This USB C stuff aint good it seems…
I think your battery is bad so maybe replace it maybe or maybe you charger is dirty or broken.
Update (01/21/2021)
I’ve had a problem like that before but we couldn’t fix it because USB was broken on the device then it went dead forever. The device was a Kindle Fire 7.
When I am going to charge my mobile with my original turbo charger it is not charging then turbo charge is showing connected. But even a percentage does not increase. Whereas I charge by using another turbo charger, it gets charged. Later, after two minutes, after one or two percent charge, I charge it back with my charger, then the same charger starts charging. So it is not understood whether the problem is in the charger or in the mobile? Please guide me what should I do to solve my problem?
Arayan Richard Jenkins crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 48,079
