My printer is not working neither the scanner
How can I remove the scanner part and make it use as a seperatw scanner. As I have another printer so I only need a scanner. Help me out.
First just use it as a scanner and do not print to it then. Most Printer/scanner combinations do not separate. If you just want a Flatbed scanner then you will have to get one. Otherwise you have your answer.
Printer tells me "scanner Failure" unable to scan, copy or send fax.
crwdns2942667:0crwdne2942667:0 235
