A home coffee brewer, released in 2011, manufactured by Keurig. Repair for this device is similar to all other Keurig models.
Why is my coffee not hot enough?
Whenever I try to use the Keurig, the coffee doesn't come out hot enough. Please help:(
It's not hot when I finish brewing
You may have a problem with your water pump. See troubleshooting page.
The temperature can also be set on the display via the menu but it is generally a sign that something else isn't working.
Why isn't my coffee hot
If you change it in menu to 192° and it still comes out cold, go to ebay. For 20 bucks you can get a new tank/boiler, usually ships free. Not a fun repair but doable easily once the case is off
There might be three possible reasons if your Keurig is not hot enough
  • There is a problem with the water pump.
  • An issue with the water pump is causing the heating system inside to malfunction.
  • A build-up of dried grounds and calcium clogged Keurig, causing malfunctions.
Jarred Hall crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 51
crwdns2936753:030crwdne2936753:0 177
crwdns2942667:0crwdne2942667:0 17,914
