Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
Ripped the home button cable, can I still fix it?
I took apart my phone and ripped the home button cable, but I didn't tear the cable, I detached it from the screen side. Now the home button does not work at all. I was wondering if there was an easy way to reattach it instead of having to buy a new part. I know the touch ID might not work, but I just want to regain the home button's abilities.
Just to be clear, the cable was not ripped in any way, as you can see by the pictures below it was separated near the home button.
crwdns2889612:0crwdne2889612:0 8
You're going to have to replace the home button. Fixing this is very tricky as it requires a some soldering skills I'm not sure if this is even possible with a soldering iron and a microscope. You might need one of those expensive flex repair machines.
I agree With Ben on this one you need to replace the home button which up till a few weeks ago was a death sentence for your phone but you can now replace the home button and not end up with error 53. you will lose the touch id function of the home button when you replace it but there is a fix for the errror that will come up when you update the phone after replacing the home button
https://support.apple.com/en-ca/HT205628
a help for replacing the home button
iPhone 5s Home Button Replacement
replacement part
iPhone 5s Home Button Assembly
Hope this helps
crwdns2886500:0Replace a home button assembly compatible with the iPhone 5s and 1st generation iPhone SE. Includes the home button, home button cable, and home button metal ring. Part #821-1648.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$9.99
@jimfixer means after updating the iOS the touch id will be able to work again with replaced home button?
Did you ever figure this out?
The cable is actually torn in your image, you just can’t see it because of the bend
Jack crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 19,506
