The Epson L200 is an all-in-one color inkjet printer, copier, faxer, and scanner.
red color not working
Sir,
Recently I purchased EPSON L220 from Visakhapatnam. While taking colour prints Red colour didn't appear.
Hi,
Try to do deep cleaning and it will take 0.4 from a total of your ink. This should solve your problem.
When you have tried twice with deep cleaning but yield no result then something wrong with your print head. This because some dirt traps on the print head and makes it can't spray the inks.
Hola ajay , tu problema con la L200 se debe a que el inyector esta tapado tienes que realizar una limpieza profunda a los inyectores con un liquido especial para destapar dichos inyectores, el problema de las Epson tintas continuas es que si no las usas diariamente se tapan los inyectores y se solidifica la tinta lo cual impide su correcto funcionamiento, espero te ayude mis sugerencias , estaremos en contacto, saludos.
ajay babu Uppada crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 4,194
