Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
Why my iPhone shows no service?
Hello.
I had Iphone 3gs 16GB and the ios was 6.1.6. It was from England and the carrier was O2. So for that I did the jailbreak and it was correct but after jailbreak it shows NO SERVICE. I asked lot of poeple and read some commentaries about that and I decided to Jailbreak again but also click "Install IPad Baseband" in redsnow. Then Jailbreak was going but It shows me "ERROR put your iphone..." in something but i dont remmerber "and then try redsnow again".
So after that It doesnt worked. I pluged in charge put show Chargong with red colour and shows Apple for some minutes and then sweaches off. I tried again but doesnt works.
The I went to Proggrammer and he told me that he must install Ios 4 , then jailbreak, then upgrade iphone to 6.1.6. He installed ios 4 and jaibreaked but in boot. So now my iphone is in boot jalbreak. I didnt sweached off my iphone because the proggrammer told me that if i do this my iphone will be die.
I wached that he cant do that and I decide to fix this by myself but only with your recommendation and good ways to fix my iphone.
Please help me in this.
Thank you for your attention!
Having no service on your iPhone can be frustrating, especially when you need to make a call or use data. But don't worry, there are several simple fixes that you can try to restore your iPhone's service.
Top 10 Ways to fix your iPhone when it has no service
  • Check your coverage area
  • Turn on/off Airplane mode
  • Restart your iPhone
  • Reinsert SIM card
  • Enable Data Roaming
  • Reset Network Settings
  • Ensure that the date and time is set correctly
  • Update carrier settings
  • Update your iPhone
  • Contact your service provider
@siavash you got an answer after 7 years 😂
@siavash Years don't matter; correct answers and presence at the right place are more important for another user.
Prince Siavash crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 89
