Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
water damage black screen
last month my phone fell in my bath tub; i used the rice and alcohol trick yet it didn't work, i even opened it. So i went to a repair shop and they said that they replaced the LCD and battery but the phone still wont turn on but it can be detected by my computer AT TIMES. I plugged it in then it vibrated and there was a sound. up until now it still won't turn on. PLS HELP ME!
illonatrinacesante the very first thing to remember is that the rice "trick" does absolutely nothing. Rice does not work for anything related to water damage and has no place in electronic repair.
The major issue you will run into is corrosion damage. The very first thing I would do is to disassemble it by following this guide. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. After that I would suggest that you clean it a couple of times in sterile water, not drinking water. Use a soft brush and clean it very, very thouroughly with the sterile water. With the amount of corrosion that I envision, you will most certainly have to remove all the EMI shields. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for a 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use sterile water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. In your case I also suggest to replace the lightning connector. The guide for that is here Keep in mind that water damage is the hardest to troubleshoot and to repair so even after all this your phone may still not work. Hope this helps, good luck.
crwdns2886500:0iPhonecrwdne2886500:0
crwdns2930805:0crwdne2930805:0
Repairing iPhone Liquid Damage
crwdns2934079:0crwdne2934079:0
crwdns2937803:0crwdne2937803:0
1 - 2 hours
crwdns2886500:0iPhone 5 Logic Boardcrwdne2886500:0
iPhone 5 Logic Board Replacement
crwdns2937801:0crwdne2937801:0
1 - 2 hours
crwdns2886500:0iPhone 5 Lightning Connector and Headphone Jackcrwdne2886500:0
iPhone 5 Lightning Connector and Headphone Jack Replacement
1 - 2 hours
illonatrinacesante crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 159
