Upgraded version of the Ascend P6, featuring a 4.7" 720P LCD display, a quad-core processor, and 2 GB of RAM. Released in 2014.
Power up problem on huawei ascend P6
Hi,
I have a problem with the power up of the mobile ascend p6 , its showing the first logo but than it turns off again but on charger is going on normally and can be used normally but when I unplug it it goes off again.
Thanks in advance.
If the phone is only functioning when plugged in, the phone is not holding a charge. The battery is most likely faulty, and the best course of action is to obtain a new battery and replace the old one.
How old is the Phone ?
For about 3mnts but my daughter through it in the diesel , i changed the screen and it was turning on but now is doning continues restarting
Did you try to charge that Huawei with a USB cable to a laptop ?
which shows the battery indicator in the status bar when you loaded the phone via USB after 1 hour
Maybe the battery connector is loosen
Its 96% but it doing continues reboot, how can i stop it pls ?
And the phone righg now is without the bottom cover the curved one could it effect on the phone or no pls ??
here a introduction for a factory reset ----> you will lost all your data on the phone !!!!
have you a backup ?
http://www.hardreset.info/devices/huawei...
good luck
PS. the bottom cover has no effect on it
Why my huwei p6 is switched off and on by itself.
Rodania Bugeja crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 1,034
