Repair guides and support for riding lawn tractors sold under the Murray brand name, currently owned by Briggs & Stratton.
will not turn over when the spark plugs are in.
I have a murry 20 HP motor will not turn over when the spark plugs are in. But will if they are out. Any recommendations?
crwdns2944067:04crwdne2944067:0
@dougtractor you are using the proper sparkplug? Make sure that the ones you are suing are not to long. If you are, then it is possible that you either have a bad starter that will not provide enough torque to turn the engine over during the compression stroke or you could have a timing error that will cause your cylinders to flood. What does the plug look like when you remove it? Is it wet? You checked your battery to make sure it has enough power to turn the engine over? what model is your Murray? what engine does it have?
Ok i have a 17.5 hp bridge an straten. I take the plug out the engine will turn put it in it want. Put a new plug an coberaitor idk why its not wanting to
did u fix it? mine got same problem.
I have a 20 horse single cylinder Briggs& Stratton on my Husqvarna with the same exact issue. I pulled the plug out. Nothing comes out of the cylinder but turns over fine with the spark plug in. It will not spin over brand new battery. Checked all the terminals. It's like it's hydro locked but it's not. When I pull the plug out nothing but air comes out
@dougtractor, could be a bad starter which will not have enough power to turn the engine over once it is under compression. Depending on your engine, this could also be caused by valves that are out of adjustment. That would cause a compression release to not work and the starter does not have enough power to turn the engine over. A faulty camshaft can also be a cause, so this will all depend on what engine you have
I'm having same issue turns over when spark plug is out, I have a troybilt pony with 17.5 engine, plenty of voltage to starter, I advanced the rotation of motor till after the compression stroke and hit the key it wi spin till it hit compression then stops and clicks any idea what may be the solution
I had the same issue on my dad’s lawnmower Troy bilt 20 hp Briggs and Stratton. It ran for him but I went to use it it dead headed. I as well thought bad starter or bad battery. I did my research intake valve was out 1/8” exhaust valve out 3/8 of an inch I looked at spec adjustments called for .003 in. On intake and .005” on exhaust, no bent rods how he got lucky on this is beyond me.
Agree about the valve clearance problem.
Doug crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 51
crwdns2942667:0crwdne2942667:0 10,024
