How do you get coins out of an xbox one?
my youngest son is autistic and has fed about 4 £1 coins and about 5 50p pieces through the disc slot and now i cant get them out and my games wont play can anybody help please?
My son inserted several playing cards in there. I used the blade of a snap-off box cutter, put a small piece of doublesided tape on one end. First i used the non taped end to left the lip and with a flashlight looked to locate the cards. Then i slid the taped end in, with the tape up, inserting the blade low to go underneath the cards and push up to stick a card, press the blade down and slowly pull out. The lip will try to resist at first so proceed patiently
look on the side were the button is there is a orange hole use a paper clip and push down
The only way to get them out is to remove the disc drive and open it up and remove them. Here is our video that shows the process.
I put xbox upside down and put a disc in halfway and kept ejecting it. I hit the sides and shook it. I did this several time. The items inside worked its way out. Hope this helps someone!!
Ive taken many consoles apart and its always ended in tears im heavy handed i guess so i tried this first and i have to say it worked i removed 9 items from my disk drive thanks to my 18 month old devil son and after months of no Xbox its finally working again so thankyou very much
Thank you so much!! It worked!
Yes! This worked for me too! Thanks so much! Really didn’t want to pull the whole unit apart.
I had a snapped disc stuck in there. (3 year old was putting it in and managed to snap the disc) I put an old dvd in, turn the console upside down and hit the eject button. It chocked trying to get the dvd out and managed to be pulled out along with the broken disc. Worked a treat!
Worked perfecty- Thanks!
alisonwaddington crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 31,050
