Guides and repair information for the second-generation of the North American Honda Odyssey, produced between 1999 and 2004.
2004 honda odessey problem.
my 2004 honda odyssey cuts out while driving
all of the dash lights come on and the engine shuts off
start the car up again and runs fine for awhile. A few days later it does it again.
Also the green key light will stay on after each occurance
A very intermittent problem.
Thanks.
My radio need code it not working
Did you find out what was causing the issue?
I have seen this before and it has to do with the chip the car needs to read in the key . There is an rdf reader in the steering column that is shorting out and setting off the security to kill the car. it blanks out when hitting a bump and the chip in the key looses its signal and all of a sudden the security kicks in and kills the car. Something to check . Do you have more than one key for the van ? If so try a different key and see if it makes a difference. Hope this helps
Taller crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,244
