Are These Charging Contacts Burned on my Surface RT?
So this has happened, not quite sure what to do, I've ordered a new charger, but also want to know if I should be replacing the charger port? Is there someway to clean it or is it toast? I have found the instructions and parts here, I could do it, just wondering if I MUST..... The Surface RT is working but I don't want to use it until I get this sorted out, I use it daily, but have other computers, will be going through withdrawal .... All help appreciated, thanks in advance.
New charger arrive, the second I plugged it in I smelled burning, so I know it's not the charger, next step is replace the port and then if that doesn't work, get a new tablet ...
Replace the charger and clean the contacts on the tablet with some alcohol and use #0000 steel wool (very fine) to remove anything that will not come off w/ the alcohol. Make sure the tablet is off if and when you use the steel wool. You could also use a plastic bristled brush. Nothing too abrasive.
I have already ordered a charger and didn't want to use it until I sorted out what to do with the port. Thank you so much for the advice! :)
No problem. Thanks for the upvote.
Did the new charger alone work for this? I also experienced this issue/problem.
The new charger hasn't arrived yet! Bah!
Where did you order your charger from? Just wondering so I'll know not to order from there. lol
shanonmc crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,363
