Battery door wont open
Any idea how to get it open seems to be stuck
To open the battery door on this camera
If the lock switch won't move, it may be stuck due to dirt, or corrosion inside the battery compartment. A drop or two (not more!) of WD-40 might help in getting it moving again.
If the lock switch moves but the battery cover won't, either the locking mechanism is broken and stuck, or the battery cover itself is stuck, the latter is likely due to corrosion in the battery compartment. Apply a few drops of WD-40 around the seam of the battery door, wait a while and see if the battery door will move. Repeat the operation if necessary. Don't force anything. If the battery door still refuses to budge, take the camera in for servicing. Same thing holds if the battery door will open but there's abundant corrosion due to batteries having leaked.
If you succeed in opening the battery door with the aid of WD-40, remove any traces of the latter with a cotton swab and some alcohol: the solvents in the WD-40 may attack the camera's finish.
Thanks soooo much I will give that a try! What would the world be like with Duct Tape and WD-40? :))
Believe it or not, I seldom use either. Instead, I use Kontakt 70 and gaffer tape, but these are more difficult to get hold of for non-specialist. :)
I got a rubber finger tip from office depot. Cut and Sewed on strap. Great!
Thank you so much. I was struggling and you have saved my time and temper.
Finger tip from Office Store. Sewed on. Works great.
crwdns2936753:030crwdne2936753:0 91
crwdns2942667:0crwdne2942667:0 28,304
Mine wont close. So the camera don not fonction anymore...
crwdns2934271:0crwdnd2934271:0 Alfie EHL crwdne2934271:0
I have a similar opposit problem. My camera's battery/door wont closed, so the camera do not work at all since. What should i do? I love this camera: Canon PC1310
