Starts one kick but revs really high.
I have a 1982 suzuki fa50 it starts right up but wants to take off the throttle cable isn't stuck and I cleaned the carb. What can cause this?
The carb usually has a set screw on the side of the throttle body that governs the throttle opening for the engine to run idle. Look at the carb from the left side of the bike, there are two screws. The one on the right (closest to the air intake) should be turned all the way in - gently! - and then one and three quarters of a turn out. The one on the left (closest to the cylinder intake) is the idle adjustment. Officially it should be set so that the engine will idle at 1500 rpm. If you don't have a rev counter, set it so the engine idles smoothly with a reasonable safety margin before it engages the clutch.
@flyingdutchman hope you do not mind me adding an image of the carb to your great answer.
@oldturkey03 thanx, you're welcome!
U may have you idle screw turned in to far,or u r running too lean
Air leak somewhere!!
crwdns2942667:0crwdne2942667:0 7,783
I'll try it tomorrow morning. Let you know thanks
crwdns2934271:0crwdnd2934271:0 Dominick caswell crwdne2934271:0
