dishwasher will not start
whirlpool quiet partner I dishwasher..clean button keeps flashing on status panel & dishwasher will not start?????
Reset it by pressing the keys HEATED DRY - NORMAL - HEATED DRY - then NORMAL again in sequence within 5 seconds. All the lights should come on and it will begin a diagnostic cycle. Either let it run, or press cancel and the board will be reset so you can try a wash again. If this fails please give us the model number located inside the door
Also try this:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
A true renaissance man. +
The information posted above worked. Thanks!
Is there a reset sequence for the Whirlpool Gold Series dishwasher?
IT WORKED!!! Thank you Mr. Genius for saving me money, headaches and wrinkled fingers!
This did work, but it stopped at the wash cycle, with the dishwasher full of water. I was able to empty it by your second suggestion. Could you provide an answer on why it's stopping at the wash cycle?
Hi @ shaun melton
If there is power at the dishwasher, then there may be a problem with the door latch contact not making properly or faulty, preventing the dishwasher from starting.
If there appears to be no power at the dishwasher it may be a problem with the high limit thermostat.
crwdns2942667:0crwdne2942667:0 26,350
My Kenmore washer is 2 yes old. I noticed the gel packs in base n dishes were dirty. Now the control panel is stuck on quick wash and will not start washing. There is standing water in base and the only setting that causes dishwasher to hum is the drain function which isn't working hence the standing water
crwdns2934271:0crwdnd2934271:0 Kim Zeman crwdne2934271:0
It did not work for me. The cancel light and the heat light are on. Reset, hit start and same thing again
crwdns2934271:0crwdnd2934271:0 icemate crwdne2934271:0
@icemate ,
What is the make and model number of the dishwasher?
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
