Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
Back button not working after display replacement
After a display replacement the back button isn't working. It doesn't light up and doesn't respond to touch.
Does a daughterboard replacement will fix the issue or is related to screen/digitizer?
The back button is integrated in touch function and this function is build in display. so there is a line in touch which could be broken and thats why button not work. change display is a fix.
Since I just replaced a Samsung Galaxy S6 screen yesterday, it's probably the touch sensor button cable which is connected to the charger port flex assembly. Sounds like you've cut or damaged the flex cable on accident.
So home button and finger print work, but the back button does not work at all and the menu button works and lights up?
Anyway, the charger port assembly has two separate cables going to each corner for each touch sensor.
TL:DR - Yes, a daughter-board replacement will fix this issue (Charger port flex assembly). Problem is that you will need to take out the screen again.
Next time if you do open it, you will need to start lifting up the screen from top then to bottom. Then you can separate the touch sensors being glued to the glass by using a spudger between them.
I also replaced both the screen and charger module. The back button lights up and I am pretty sure I didn't cut any cable. Following suggestions online I was able to activate the back buton more than once but it doesn't last.
It just goes away whenever I "log out".
I think it's a compatibility issue as the parts I replaced wasn't Samsung parts.
Instead of trying to fix this issue forever : I just downloaded an app with a back button from G Play.
It's sensors are inside Lcd , only lights are in charging cable , get your lcd replaced , it's damaged .
I repair phones and I have experimented it
Hi my initial thought was exactly what you are referring to the sensors inside LCD. My recent and back button both light up when I start the phone up from the phone being off. So when Samsung loads my buttons light up after I get into home screen lights don't work anymore. So my thought was that there is a tiny cable attached to the charger port which I did replace , I am thinking the cable is loose? The keys work but don't light up once I am in the home screen.
hello, I have the same problem on a S4,
home button works but back button and options do not.
I changed the display, the entire display, so I did not remove the screen or anything. could be that I damaged some cables during the process? any idea on how to proceed? the daughter board would be that little extra piece at the button with the 4 screws?
I have a blue cable in there, I guess bring power to the buttons, the home button works so that cable should be ok right? what else can be damaged?
thanks a lot!
Did you find an answer to this? I also changed the screen and digitiser on my 8 inch galaxy tab a and I can't get the apps and back button to work. The screen is fine, the touchscreen is also fine.
Riccardo Bicelli crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 30,518
