Released on July 28, 2014, the Samsung Galaxy S5 mini is a cell phone that features an 8 MP rear camera, 720p display, fingerprint scanner, and water resistance. It has a larger display, increased battery life, and an updated camera from its older brother, the Galaxy S5.
S5 Mini Screen issue "Shows static"
Hello,
I just replaced the entire Lcd/Glass/touchpanel with a new kit. Everything went fine until I switched on the device. Everything seems to be working OK :
- Phone starts up
- Welcome sound
- Is recognized and reachable via USB connected to PC
However the screen does not function correctly. It is like static on an old TV set. (See picture) I tried several times to gently press on the screen connector and such but no difference. Any ideas ? Many thanks for your help !
Tony
Had this issue once with a HTC One M8 new screen. Turns out it was faulty. Luckily your phone isn't damaged as this has also appeared on a Samsung Galaxy S3 when it's charger port was changed using the heatgun method.
Almost certain the screen is at fault as the phone still functions, just the screen not working.
Hello Ben, thanks for the reply. That is what I suspect as well. However I saw some other posts on internet saying it was a badly attached connector. I repetedly removed and inserted the one but same result so yes probably the display is faulty.
Kind Regards,
Tony
πως το διορθωνουμε αυτο το ποβλημα?
it could be the screen.. but i also had issue with one.. the fault rather tends to be a software issue... i was brought back to normal by flashing (not factory reset).
how do i fix this problem?
by flashing it with Odin
tonyknors crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,223
