Washing machine pouring water continuesly
Hello..I am using fully automatic top load washing machine Panasonic NA-F70B2 ...yesterday it suddenly had a blast after few minutes of cycle started...I saw lil smoke and smell coming out of it...i call a repairman...he replaced the inlet valve and the fuse...then i turned it on and the water started immediately even before i adjusted any program...and won't stop while overflowing... then he replaced the pressure switch... but the problem remains..he is saying the main control panel is gone...but everything else is working fine other than the water supply problem...can it really be the control panel?
crwdns2944067:05crwdne2944067:0
@msuns can you add a couple of images of your control board and the area where you think the smell is strongest? Use this guide Adding images to an existing question for that. Also, what exact model is your washer?
crwdns2957956:0crwdnd2957956:0 oldturkey03 crwdne2957956:0
@oldturkey03 I added the photos...the model of my washing machine is Panasonic NA-F70B2...There was a strong smell in the inlet valve which I replaces...but the is still burnt smell in the white port in the picture...
crwdns2957956:0crwdnd2957956:0 Nusrat Jahan crwdne2957956:0
Oh it's the same predicament of my Panasonic Automatic washing, I replaced the inlet valve with an original part, still the water continues to pour in into the drum.
I check everything the hose, the main drain if there are clogged thing on it.
Its the main mother electronic board that is already defective or it's time to retire. I bought my unit in June 26,2016 and it's now September 21,2026. The machine is retired. It no longwr function as it was before, the button I need to press it many times before it started to light it's indicator.
The mother board it's useless to order it, it's like buying a new unit.
crwdns2957956:0crwdnd2957956:0 Rommel Billena crwdne2957956:0
This is a disaster. You're only way out of here begins with locating the part which burned and identifying it. Since the images you provided do not show any burnt markings, you need to keep looking.
crwdns2957956:0crwdnd2957956:0 Jade crwdne2957956:0
The issue on machine was solved successfully after replacement of transistor which failed on the board in open position.
crwdns2957956:0crwdnd2957956:0 Saad Qudrat crwdne2957956:0
