Repair and information for the Amana AFI2538AE* refrigerator—a 2017 model with a bottom freezer, door-accessible ice, and both drawer and door access for the refrigerator compartment. This page covers information for model numbers matching the pattern AFI2538AE*.
My refrigerator is not cooling
Amana, model: AFI2538AEQ4
refrigerator control panel light are not working and is not cooling either.
When you open the door does the light come on?
Most Frequent Causes for Refrigerator not cooling
Cause 1
Condenser Coils are Dirty
The condenser coils are usually located under the refrigerator. They dissipate heat as refrigerant passes through them. If the condenser coils are dirty, they won’t dissipate the heat effectively. As debris builds up on the coils, the refrigerator becomes less efficient, causing the refrigerator to work harder to cool down. If the coils are significantly dirty, the refrigerator will not be able to maintain the proper temperature. Check the condenser coils to determine if they are dirty—if the condenser coils are dirty, clean them.
Cause 2
Evaporator Fan Motor
The evaporator fan motor draws air over the evaporator (cooling) coils and circulates it throughout the refrigerator and freezer compartments. Some refrigerators have more than one evaporator fan motor. On refrigerators with only one evaporator, the evaporator is located in the freezer compartment. If the evaporator fan is not working, it will not circulate the cold air to the refrigerator compartment. If this occurs, the freezer may still get cold, while the refrigerator will not get cold. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor.
Parts
Mfg Part # WP2315549
Condenser Fan Motor
The condenser fan motor draws air though the condenser coils and over the compressor. If the condenser fan motor is not working properly, the refrigerator won’t cool properly. To determine if the fan motor is defective, first check the fan blade for obstructions. Next, try turning the fan motor blade by hand. If the blade does not spin freely, replace the condenser fan motor. If no obstructions are present and the fan blade spins freely, use a multimeter to test the fan motor for continuity. If the condenser fan motor does not have continuity, replace it.
Parts
Condenser Fan Motor
Mfg Part # WP2188874
crwdns2886500:0Moves air across the condenser coils to help dissipate heat.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
Whirlpool Refrigerator Condenser Fan Motor - WP2188874
$71.99
crwdns2886500:0Rotates to circulate cold air within the refrigerator compartment.crwdne2886500:0
Whirlpool Refrigerator Evaporator Fan Motor - WP2315549
$139.99
mssotomargie crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 592
